1976 Dodge Dart Rear Frame Rails
Old 01-21-2020, 09:10 PM
'76DodgeDart's Avatar
I'm in the process of restoring a 1976 Dodge Dart 4 door sedan. Currently, I'm confronted with a rear frame rail issue. The back of the driver's side rear rail is pretty much gone. It's all still there, but when I pick at it, it pretty much just falls apart. This is only on the very rear of the car, only starting about halfway between the back of the wheel well and the back of the car. Forward of there, it's still good. Would I be okay simply fabricating a new section of rail, cutting the old rotted section off, and welding in the new fabricated section?
Old 01-22-2020, 05:09 AM
Basically you will need to replace everything that is not solid. I generally make my parts then cut out the damage and weld the new in.
Old 01-23-2020, 06:29 PM
AMD for some of it.... Like Iowan. Fab the rest !!!!
'76DodgeDart
07-27-2019 06:30 PM
hemichallenger
07-06-2012 03:49 PM
wildbill2009
02-11-2010 03:18 AM
patscharger
02-18-2009 10:58 PM
smackhonda
11-23-2008 03:38 PM
Quick Reply: 1976 Dodge Dart Rear Frame Rails
