Go Back   Mopar Forums > CLASSIC DODGE, CHRYSLER, & PLYMOUTH MODELS > A-Body
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 07-28-2007, 04:17 PM   #1 (permalink)
Garrtt_51
Junior Member
318 V8
i have a 1969 dodge dart. it has a 318 v8. i was wondering if this is a good engine to build power with or should i buy a crate engine. if it is a good engine to build power with what should i do to it.
Garrtt_51 is offline   Reply With Quote
Old 07-28-2007, 07:48 PM   #2 (permalink)
unclemike
Junior Member
How much can you spend? The easy way is to go crate engine, no running back and forth for parts, dealing with shyster machine shops etc.
unclemike is offline   Reply With Quote
Old 07-29-2007, 12:29 AM   #3 (permalink)
Garrtt_51
Junior Member
right now iam on a pretty limited budget so which ever would be cheaper. i would like to make about 400 hp
__________________
MOPAR or No Car
Old 07-29-2007, 11:29 AM   #4 (permalink)
unclemike
Junior Member
Mopar Muscle did an article on a 318 build up that netted over 400 hp. It involved worked 360 heads and .030 pistons with enough of a dome to make some decent compression.
You are ahead of the game as far as having a forged crank in your block but lack a sufficently strong rod. The cast crank 318's got the 340/360 rod with a pressed pin. Rather than waste money on reuilding stock rods price out a set of replacment aftermarket pieces.
Since you say you are on a budget be warned that you'll be spending a minumum of $3,000.
Old 07-29-2007, 11:27 PM   #5 (permalink)
Garrtt_51
Junior Member
sweet thanks
__________________
MOPAR or No Car
Old 07-31-2007, 01:30 PM   #6 (permalink)
eric22
Junior Member
welcome to the site
eric22 is offline   Reply With Quote
Old 08-02-2007, 11:38 AM   #7 (permalink)
ucfierocharger
USB car drive man
I would suggest trying to find a 360 or a 340. If your car runs you would probably be able to find a 360 for just a couple hundred dollars and you can build it while you still drive your stock 318 around town.
I am doing just that with my charger and it was a great decision. I can still drive it around and its not stuck in the garage til the motor is finished
ucfierocharger is offline   Reply With Quote
Old 08-02-2007, 11:59 PM   #8 (permalink)
Garrtt_51
Junior Member
i would like to keep the original engine
__________________
MOPAR or No Car
Old 08-03-2007, 06:10 AM   #9 (permalink)
ucfierocharger
USB car drive man
thats understandable, but your going to spend more money building a 318 to 400hp than a 360. But like it was said, It IS possible, just expensive.
Old 08-03-2007, 10:00 PM   #10 (permalink)
Garrtt_51
Junior Member
yeah i realize that but iam not expecting to get the car and then in a month have all the work done that i want done
__________________
MOPAR or No Car
Old 11-09-2007, 08:06 PM   #11 (permalink)
440roadrunner
Senior Member
Just my opinion, but I think you're going to find it really expensive to get that kind of power out of a 318. For example, you can throw away your present heads, intake, cam, pistons, and rods.
Not much left, is there?
440roadrunner is offline   Reply With Quote
Old 01-29-2008, 02:56 PM   #12 (permalink)
CAT-TECH
Member
CAT-TECH's Avatar
You can make decent power out of a 318 and still have it very streetable but when you shoot for 400+hp natural aspiration with no NOS you will lose some of your reliabilty and streetabilty. As to how much you lose depends on just what you do to make that power. I would say keep your 318, do intake manifold, new carb, headers, high flow exhaust and see how you like the power of the engine then.
CAT-TECH is offline   Reply With Quote
Old 02-18-2008, 11:41 PM   #13 (permalink)
74SWINGER
Junior Member
Where can I find a 360 then to put into my '74 SWINGER because I too am aiming for 400hp. Any ideas on where I can get a MOPAR 360 to drop into my dart?
74SWINGER is offline   Reply With Quote
Old 02-23-2008, 03:11 PM   #14 (permalink)
kmn5
Junior Member
hmmm, 400hp.. interesting stuff
(Btw: do you guys quote at the crank hp or at the wheel hp?)
kmn5 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
LinkBacks Enabled by vBSEO 3.0.0
Dodge | Ford Mustang | Harley | Motorcycle Forums
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61
