68 Dart 318 2bbl stumbles
Old 01-17-2009, 04:42 PM
the fuel/air misture or idle could be off too. I'd double check your timing, look for any and all vacuum leaks and adjust the gule/air mixture.
Did you do anything else to the powertrain beside having the carb rebuilt?
Old 01-17-2009, 06:50 PM
Polaradude's Avatar
I agree with 78d200 and 66, the only other thing not mentioned is fuel filter but it sounds more like what the boys said above.
Old 01-18-2009, 06:05 AM
Crazy4Carz.Com's Avatar
There is an adjustment on your accelerator pump. This is the part on the carb that squirts the gas in when you press on the pedal. The fuel is sucked from the bowls through the carb venturis with the air that is going through the carb. when you press on the gas initially the air gets in but there is a delay in sucking up enough fuel. this creates a temporary lean situation. The accelerator pump squirts a little fuel into the carb on acceleration the compensate for this. My guess is the accelerator pump is not re-installed correctly (if it was not doing this before) or is out of adjustment.
Old 01-20-2009, 06:01 PM
challenger's Avatar
Im with c4c on the pump , try the upper hole on the rod and plate - you should have three holes in the plate but i could be wrong
82mirada
04-10-2011 07:57 AM
65fury
10-31-2010 08:52 AM
Rosfrei
05-29-2009 07:50 AM
premiumdan
02-09-2009 05:52 PM
67coronet440
11-11-2008 06:30 PM
Quick Reply: 68 Dart 318 2bbl stumbles
