74 Scamp, fuel gauge doesn't work...sending unit?
Old 04-11-2009, 07:55 AM
an 8 3/4 rear end has a welded on back peice on the rear
Old 04-11-2009, 04:29 PM
theomahamoparguy's Avatar
I think your gonna have to drop the tank to get the sending unit out.
You can get a new tank through many outlets, yearone sells them.
You can also get the new straps and sending unit. I think all the A-body gas tanks from 1971 to 1976 are the same. I changed mine on my duster cause of all the rust and sedimentation {1 1/2 inches thick}. I think the new tanks cost about $250 . Yearone has the sending units, FD169 part number, priced at $119.
As far as the rear end goes ill bet you have a 7 1/4 rear end. The 7 1/4 rear end has a rear cover on it with nine (9) bolts around the perimeter.
So if you peak your head under the rear bumper and see a cover on the rear end with nine bolts its a 7 1/4. You may have the 8 1/4 rear as the only other option that year in your car, It has ten(10) bolts and is more rounded on the rear cover, and the perimeter is more of a diamond shape.
[kind of like a square standing on its corner]
9 1/4 did not come in a A-Body {like your scamp}
Old 04-12-2009, 05:36 AM
That looks like a dana 35 (lol). Are there any tags or stampings that you can pull from it?
I'm thinking its a 8 1/4.
Old 04-12-2009, 06:15 AM
Commando's Avatar
I believe that is an 8 1/4. I know I have seen enough of them as out the last three claimed 9 1/4s two turned out to be 8 1/4s.
If you want to confirm this there is a part number on the side of the diff.
Old 04-12-2009, 08:44 AM
yes it is an 8 1/4. sorry I confused you. I was thinking of the mounting surface for the cover. [ I think it looks a little diamond shaped.] The 9 1/4 is the one that has a diamond shape for sure [sort of, like with the corners trimmed a bit].
Anyway, congrats on the scamp and you shouldn't have to worry too much about that 8 1/4. The axles have circlip retainers, meaning youll have to remove the cover and remove the clips to remove the axles. After that you can take it down to the NAPA or someplace that has a press and have them press on your new axle bearings and seals. They are held on with a pressed on collar.
Old 04-12-2009, 09:37 AM
I know for a fact that the 9 1/4 and 8 1/4 that chusler made in the late 80s to now are diamond shaped.
studellac
08-27-2012 06:53 PM
Ramahan
02-05-2011 05:43 AM
mopar nate
01-25-2009 09:12 AM
nailbender
10-09-2008 06:47 AM
64fury
06-16-2008 12:40 PM
Quick Reply: 74 Scamp, fuel gauge doesn't work...sending unit?
