advice on adjusting edlebrock carb
Old Jul 26, 2008 | 11:33 AM
gotdust's Avatar
i have a edlebrock 600 cfm electric choke, any tips on adjusting mixture, i have a vacuum gauge if that helps? thanks
Old Jul 27, 2008 | 05:07 AM
depending on the motor you are running and how built up it is, a good starting point is to have the fuel and air mixture screws turned 1.5 turns out from being fully screwed in. after that, you'll need to watch the RPMs and adjust them accourdingly to get it to idle at the right RPM. The idle screw is already adjusted out of the box and doesn't need much turning, if any at all.
Old Jul 27, 2008 | 07:25 AM
gotdust's Avatar
thanks will give it a try
mrzods13
Feb 24, 2014 07:56 PM
Dave E
19
Jul 30, 2013 07:08 PM
auerdoan
Feb 17, 2011 08:09 AM
auerdoan
Dec 17, 2010 05:53 PM
gotdust
Jul 27, 2008 07:27 AM
