Grinding Noise From Heater Fan ?
Old 05-01-2009, 06:46 PM
Crazy4Carz.Com's Avatar
The smoke and grinding noise are obviously not related. First the grinding noise, There is **** in your blower motor. Could be just leaves and debris or could be a mouse nest. Just clean it out and you'll be fine. Likely not a bad fan motor.
Second the smoke, I guessing the rings are not sealing. Drive it a little and see if it clears up. If the smoke is bad or gets worse, STOP.
Bluehen
11-28-2012 04:31 PM
Cazbah362
06-12-2011 01:05 AM
mytracy
12-29-2010 08:20 PM
silvermopar
10-11-2009 09:07 AM
gilesie
07-14-2008 02:29 AM
Quick Reply: Grinding Noise From Heater Fan ?
