I need help with my trans 904
Old Mar 11, 2010 | 05:58 PM
73 dart swinger's Avatar
Junior Member
I am replacing the shift linkage seal on my 73 dart swinger, which has the 3 speed 904 auto, how do I correctly press the seal in the transmission ? Do I have to lower the trani or is there a press to apply pressure evenly to not mangle the seal?
Old Mar 11, 2010 | 06:02 PM
Junior Member
Can you help with my 904 trans?
Old Mar 11, 2010 | 11:50 PM
1966sportfury's Avatar
A.K.A Bob Dodge
i dont think ive ever had to replace that seal? could you use a socket the same size as the seal and lightly tap on the socket?
Old Mar 12, 2010 | 05:56 PM
volaredon's Avatar
Member
727 has same seal. I know an A body tunnel is a bit tight.
Old Sep 18, 2011 | 12:23 PM
flakeyrods's Avatar
same problem, just bought a 68 barracuda, leaking like a goodun from linkage seal in casting just above pan, would also like to know if its an easy fix
thanks fintan
Old Sep 18, 2011 | 02:16 PM
You can get tools like this:http://www.amprotools.net/product_li...id=5&mode=show
But you still have to drive it in, manual says 15/16" socket. I think there is some tool that pulls it in with the pan off. Lowering the trans a bit is not a big deal if you loosen the motor mounts so as not to rip the rubber.
Old Sep 18, 2011 | 09:21 PM
BUY an extra seal. You will have to lower the trans to gain clearance / Working room. Getting the correct tool is a good idea !!Makes the job much easier esp when working under the car !!!
gpepiton
Jan 22, 2014 05:38 AM
gsxrred1000
Jul 8, 2013 10:39 PM
89PowerRam
Jun 24, 2010 03:33 AM
78cordoba
Oct 10, 2009 06:28 AM
