Nearly killed myself in the Dart today :(
Old 02-19-2012, 02:10 AM
1966DartConvertible's Avatar
It was 95F outside, I was happily driving with the top down... then.. at the gas station as I was trying to fill her up...
The exhaust heat combined with the 95F weather had melted the paint on the side of the gas tank as well as the filler neck seal...
Here is whats left of the filler neck seal...
Glad I wasnt smoking at that time (not that I am a smoker...)
Syed
Old 02-19-2012, 08:12 AM
I don't believe heat was the cause of that. I don't know what did, whether there was something in the fuel that disintegrated the seal, or whether the seal was a poor quality "repop" or just what.
What happened is, that something caused the seal to leak, the gasoline itself damaged the paint.
There's been thousands of Mopars with the very same type filler neck seal drive hundreds (millions) of miles and did not suffer that sort of damage. There are places in the US (death valley, example) where the temp gets way higher than 95F
Old 02-19-2012, 10:10 AM
Not a good idea to smoke when your filling up you car. So what happened after you sprung a leak?
Old 02-19-2012, 04:29 PM
I agree that the gasoline was melting the tank and not heat (although at 1st I thot it might be caused by exhaust heat). I also think I saw some left over silicone on the old filler neck sealant... Hmm... someone was trying to be smart-a$$ when fitting the tank before...
Old 04-03-2012, 08:06 PM
chlngr1970's Avatar
Dammn, I thought for sure you were going to post pix of a crispy Dart ragtop. SOOO Glad that didn't happen.
j
deadkelly
05-25-2013 10:01 PM
blue 68 gts
06-12-2010 03:04 PM
irishman
05-29-2010 05:07 PM
dartcuda
03-22-2009 08:22 AM
Red Devil
03-20-2009 11:17 PM
Quick Reply: Nearly killed myself in the Dart today :(
