New to Mopar...69 Dart engine swap question
Old 05-29-2010, 11:47 AM
Junior Member
fpereira23's Avatar
Hi,
I´m new to Mopar but to not to rebuilding muscle cars. I got a 1969 Dart with a slant 6.
I want to swap the engine to a V-8 (will be using schumaker kits) but my problem is locating the engine.
I live in Panama, thus there are no easily available engines, however there are old 70s cars laying around. I'm pretty sure I can find an early 70's Coronet or similar with a 318. If I do get this donor car, what else could I use from it? Transmission? Rear End? Front disc Brakes? What about the drive shaft? (i guess this one will not work as those are different bodies)
What about a Big Block? Which car should I look for to get a 440?
What about a 360 from a van or truck?
TKS any help will be appreciated!!!
Old 05-29-2010, 01:11 PM
blue 68 gts's Avatar
Alot of C-bodies came with 383s and 440s... You get the motor, trans and rear end. Need to change the tailshaft housing, and have the c-body housings cut down with some axles.
Or you get an 8 3/4 Abody housing and your set.
And you'll need a new driveline
Old 05-29-2010, 04:59 PM
dodgenut7's Avatar
yep blue 68 covered what you need..... oh one more thing take the radiator also you will need it to keep the new motor cool especially a big block
Old 05-30-2010, 09:16 AM
mopardrt's Avatar
check out craigslist in your local area should be plenty, I have 318s 340s 360s 400s and 440s laying around in my garage, dosent evreybody?
Old 05-30-2010, 09:25 AM
Old As Dirt
Sgt. Veteran's Avatar
Yes .... and a couple in the kitchen when I was last there lol
Old 05-30-2010, 12:30 PM
I have a complete 400, another short block assy that will make a 500" and a slightly hurt piece that I hurt this weekend at the Southern Mopar Nationals.... Isn't that everybodies garage?????
Old 05-30-2010, 12:46 PM
Old As Dirt
lol yep!!
Old 06-01-2010, 11:43 PM
chlngr1970's Avatar
Too bad shipping to Panama from Washington would be a killer...I've got a 440, 2 good 400s, one 400 boat anchor, a 360, 340 and two 318's. My GF is not happy about all that either LOL
Agree about Craigslist tho...good source for parts, if you come across the right people. Also, look for any car clubs in your area. They can be a big help.
j
Sovereign
09-08-2010 11:48 AM
smackhonda
05-26-2009 07:05 AM
bertakus
01-30-2009 09:25 PM
fpereira23
01-26-2009 06:49 PM
smackhonda
07-28-2008 07:46 PM
Quick Reply: New to Mopar...69 Dart engine swap question
