Quick changes to make my 340 roar
Old 02-12-2009, 06:45 AM
thinkin with me dipstick
johnthegoalie's Avatar
i remember reading a while back that the traction bars dont work on old mopars due to some leaf spring design that is unique to them. on my 8 1/4, i have the mp adjustable pinion snubber. as far as suspension, i went ahead and got all new components along with polyurethane bushings. you can't go wrong with a set of bfg radial t/a's. with sizing -if you have a discount tire, they will take the time to test fit different sizes.
oh - sub-lime looks awesome on an old a-body...
Old 02-12-2009, 07:26 AM
Lets start with performance. You've got your intakes, carbs, headers, full dual exhaust with x-over pipes, ignition upgrades, cams, pistons, heads, tranny shift kits, etc. Since you've already got a carb and exhuast, I would look into an intake for it and ignition upgrades (coil, wires, orange box). Next I would take a look to see what is out there for shift kits for the 727 tranny.
As far as suspension goes, john is right with the poly bushings. Belltech, Hotches, Addco, are all good companys a long with Mopar Performance. I would get a set of solid (or really thick at least) front and rear sway bars. They will help you out with corning a little more. I good set of stiff rear leaf springs with some poly bushings are always good. I don't think you will need to look at ladder bars unless you are pushing out some serious power out of that 340 you've got. For the front, replace the coils with a well known company, most you can get as a complete kit for the front. Also get a good set of shock all the way around.
Check your posi unit to make sure that it is still good. The can wear out and start to lose their grab over time. There are rebuild kits out there for them.
Once again though, its your car, do with it what/how you want. You've got a great base to start with though.
Old 02-12-2009, 07:30 AM
As for tires, there are a lot of choices out there. Look around for what fits your needs/wants. Make sure you pick a tire that suits how you are going to drive the car. You don't want to put drag radials on and drive it every day and in the rain.
Old 02-12-2009, 03:48 PM
how much do you drive the car?
Old 02-13-2009, 01:15 PM
Do you cruise with it? Drag racing it when you can? What RPM range do you see normally and expect to run in?
Old 02-13-2009, 01:24 PM
intake - http://store.summitracing.com/partde...6&autoview=sku
dizzy and orange box - http://store.summitracing.com/partde...5&autoview=sku
sway bars - http://store.summitracing.com/partde...5&autoview=sku
and - http://store.summitracing.com/partde...5&autoview=sku
This here is a small list of the basic stuff that you could install. You don't have to go with these items.
Old 02-15-2009, 02:04 PM
I would just stick with a bunch of add ons in the lower RPM range (5500 RPM and lower). Since your not really going to be getting on it like you would at a drag strip, there is no reason to spend the money on high end power.
Lok for intakes that range from idle to about 5500 or 6000. I'm kind of partial to Edlebrock, they always seem to fit just right. I've had Holley and Weiand and I had nothing but problems.
VALNUT
08-13-2014 07:37 PM
rcknrolfender79
04-09-2010 10:47 PM
printdoc
07-25-2009 09:13 AM
printdoc
05-15-2009 12:54 AM
Quick Reply: Quick changes to make my 340 roar
