Go Back   Mopar Forums > CLASSIC DODGE, CHRYSLER, & PLYMOUTH MODELS > A-Body
Thread Tools Display Modes
Old 09-30-2008, 07:00 PM   #1 (permalink)
1969dart
Junior Member
Talking starting problem
me and a friend of mine installed a new disturber in my 69dart and can't get and spark at all. the part we put in is from summit racing parts. any help
1969dart is offline   Reply With Quote
Old 09-30-2008, 07:38 PM   #2 (permalink)
Commando
Senior Member
Commando's Avatar
Welcome to the forums.
Did you just pull the old one out and put the new one in? Was the old one points? Did you recheck the timing?
Commando is offline   Reply With Quote
Old 10-01-2008, 01:35 AM   #3 (permalink)
Ph.D in wheelinology
Send a message via AIM to 78D200
if you can give us a link to the exact dizzy you installed, we can probably tell you what you need to do or where to start.
__________________
Tim and Heather
1974 J10 - getting built up some more. built 360, built TH400, D300, D60(detroit)/14B(spool), SOA, inboard rear 64" springs, 38.5 thornbirds
jeep pics - http://s149.photobucket.com/albums/s63/jeeping1974/J10/
78D200 is offline   Reply With Quote
Old 10-01-2008, 02:44 PM   #4 (permalink)
1969dart
Junior Member
we did what the paper we got from the company. it is a summit one.
Old 10-01-2008, 03:35 PM   #5 (permalink)
http://store.summitracing.com/egnsea...256+115+400304
which one did you install? there are 6 to choose from.
what motor do you have? have you checked to see if your coil is putting out spark? do you have power going to the coil? is the rotor installed in the cap? is the dizzy spinning when the motor is being turned over?
__________________
Tim and Heather
Old 10-02-2008, 02:55 PM   #6 (permalink)
1969dart
Junior Member
i found the kit we installed sum-850003 this is a summit unit with the orange box. we also installed a accel ignition coil superstock.
Old 10-02-2008, 05:01 PM   #7 (permalink)
do you have power getting to the coil? do you have spark coming out of the coil?
__________________
Tim and Heather
Old 10-02-2008, 05:56 PM   #8 (permalink)
ef8340
Senior Member
ef8340's Avatar
if you can tell us how you connected together the harnes that comes in the kit have the same color coded wires as factory units should have example black/yellow tracer , gray/black tracer etc etc on the electronic box it should have a plug like this
4 5 with a screw in the middle if you could tell us where you ran the wires too and we can cross refrence it for you also another thing to check could be the voltage reg i think they changed them in 72 when they went to electronic ignition plus are you using the 4 pin or 2 pin ballast resistor? either way will work but you can hook it up the 2 pin way
ef8340 is offline   Reply With Quote
Old 10-02-2008, 05:58 PM   #9 (permalink)
ef8340
Senior Member
ef8340's Avatar
argh the pin didnt show right anyhow you should get the idea
goodluck
Old 10-02-2008, 06:45 PM   #10 (permalink)
1969dart
Junior Member
yes there is power going to the coil but no spark coming out of the coil. and is it's 340 motor.
Old 10-02-2008, 06:49 PM   #11 (permalink)
1969dart
Junior Member
i have the two pin ballast resistor/ i have not check the voltage reg.
Old 10-03-2008, 01:34 AM   #12 (permalink)
have you tried it with the stock coil? I have heard of brand new coils not throwing out any spark.
__________________
Tim and Heather
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
issue with stroker engine and starting help DUST360 A-Body 11 09-22-2008 10:44 PM
starting problem with a 74 charger 440 speedtriple General Technical Questions 7 05-30-2008 04:45 AM
starting problem siliconcrunch B-Body 31 04-08-2008 11:17 AM
Starting a Local Mopar Cruise Group In Delmarva Mopar Guy in Delaware General Discussion 0 04-07-2008 11:52 PM
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
LinkBacks Enabled by vBSEO 3.0.0
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61
