Go Back   Mopar Forums > CLASSIC DODGE, CHRYSLER, & PLYMOUTH MODELS > A-Body
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 04-28-2007, 03:04 PM   #1 (permalink)
cudakid69
Junior Member
cudakid69's Avatar
Is it worth it?
I'm currently resoring a '69 barracuda. Its a 318 car with a 904 tranny. I wanted to get other peoples opinions on building up the 318. I can get a 360 really cheap, so what does everyone think? Should I build up the 318 or swap it with a built late model 360 (I would probably end up building a stroker)?
__________________
The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at or repair.
cudakid69 is offline   Reply With Quote
Old 05-09-2007, 03:10 PM   #2 (permalink)
Jonah Hex
Member
Jonah Hex's Avatar
The first question is.....Is it a numbers matching car? If it is, I personally would restore it with the 318. If it is not, there is no replacement for displacement!
Jonah
__________________
I`d rather push a Mopar than drive anything else!
Jonah Hex is offline   Reply With Quote
Old 11-09-2007, 08:08 PM   #3 (permalink)
440roadrunner
Senior Member
Yep, it depends on whether you want to keep it original. If you put a 360 in there, those engines are externally balanced, and I'll guarantee you that you can "feel" that. I don't remember if the weights are on the torque converter or the flex plate
If the 360 is out of a pickup or other rear sump pan, you'll have to find a pan. Your 318 pan won't fit, because the rear main seal on the 360 is larger.
440roadrunner is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
LinkBacks Enabled by vBSEO 3.0.0
Dodge | Ford Mustang | Harley | Motorcycle Forums
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61
