8.25 axle shafts
Hi,
I have a 8.25 axle with sure grip. My right side axle shaft is pitted. I installed a repair bearing, but it didnt help. the pitting is on the whole surface. Needless to say, it is roaring real bad. My problem is I cannot find a new axle the right length. I have the axle out, and no matter how many times i measure it, it is 28 1/2 inches long overall. 28 inches long from the outer side of the flange, to the c-clip end. the shortest replacement axle i can find is 29 3/4 inches long. i have searched by casting number, and still couldnt find a replacement. can the axle be remachined? ground down and a larger bearing installed? has anyone else ever had this problem? |
Go to a 8-3/4 Rear
Switch to a 8-3/4 rear, if you can find one. - Depending on your area, that may be difficult.
Originally Posted by Magoo
(Post 130022)
Originally Posted by randy4662
(Post 130031)
I have one! Its a peg leg. What parts do i need to make it a sure grip? Do i have to change the whole chunk or can i pull out the carrier, and just replace that? will the old axle shafts still work?
Check to see if they make a repair sleeve, Their is also a repair that moves the bearing to a different part of the Axel ??
I have a good used pair of 8.25 axles. I'll measures them.
Did you measure them?
