flat black
Does anybody have ideas or tricks on how to clean my flat black hood on my duster?? Is there anything to use on it so I can dust it and not scratch it?? Thanks!!
Originally Posted by msbhvin duster
(Post 103206)
I have the same issue with my hood. The dust normally collects while parked in the garage. I even have a cover for the car, but the cover appears to have a lot of tiny balls that come off and fall onto the car and hood. They are easily removed from the car with a cloth, but the hood not so much. I too am curious to see what might help resolve this. |
if this is the automotive flat paint it should wipe clean.
we used a additive that de-glossed the paint the more you added the flatter it became never touch it with waxes that turn to a white powder this will leave a white stain. hell i don't even use them i use pure carnuba wax if the flat is from a spray can well there is your problem. |
It was sprayed with the correct flat black automotive paint designed for the car sprayed by the best shop in my area!!
I use a California duster, Also use mothers spray wax to dampen a microfiber cloth and wipe it down. Always seems to work and not scratch the finish for me and looks great. How much dust are you talking??? What Im talking about is light dust any more than that I wash the car. I always thought it was called matte black which is more semigloss than flat. Flat black is like primer very porrous/rough and I could see where that could cause problems. From the factory I believe they where decals and were alot easier to care for. I might be wrong but I see decals listed for the Duster hoods.
(Post 103219)
pro tech has a good suggestion. |
I believe u are correct on the matte black. I will try the wax on my cali duster. I'm talking just a slight dust like just from driving down the road!!
Any flat color is going to be porous and will hold onto dirt, dust, water, etc.. Ask the shop what they actually sprayed. Was it flat, matte or satin? Did they spray a satin/matte clear coat on it as well? I painted my old Honda motorcycle satin black (looks just like flat but without the pores) and then sprayed a satin clear coat on it. After letting it cure for 21 days, I was able to wax it and never had an issue with water spots or dust/dirt sticking to it.
Do you use a shammy after washing it? Mother's make some great products too. That is all that I have used on all my vehicles for the last 8 years and won't use another else. |
i'd probably go the duster route, too.
Yes I shammy it after washing and it looks great for awhile!!!:swinging::swinging:
You could always just not let it get wet. :lol2:
