Oil on spark plug threads
Old 02-07-2017, 02:28 PM
scotch's Avatar
I have a 76 Cordoba 400 with 4 barrel. This car is all original except for the carb and is like new. The mileage is a pampered 53K. Lots of idle time instead of drive time due to storage
Last week I did my yearly undercarriage inspection and wipe down and noticed 2 oil leaks down the side of the block. Traced to the second cylinder (drivers side) spark plug. I pulled the plug, and it was loose to start, and oil is on the threads and on the perimeter but not on the electrode.
I cannot see any area above like the valve cover leaking - I will inspect closer this weekend.
The only thing that would make sense is possible carbon around the ring. I cannot see bad rings or valve seals with this engine. By the way it does not misfire.
Any ideas or comments would be appreciated. THANX
Old 02-08-2017, 07:10 PM
Sure it not a V/C gasket leaking?
scotch (02-10-2017)
Old 02-10-2017, 10:58 AM
scotch's Avatar
I'm going to have to do a closer inspection this weekend. Thanks for your reply. I will keep you informed on this gremlin.
Old 02-10-2017, 12:05 PM
Big blocks of this aira had a problem of cooking the valve cover gasket, exhaust manafold is close so there is more heat than normal.
scotch (02-10-2017)
Old 02-10-2017, 12:26 PM
scotch's Avatar
oil on spark plug threads
I will check that out. I have changed the gaskets out some time ago but makes sense. THANX
Old 03-28-2017, 05:02 PM
xtopfuel's Avatar
X2 on valve cover
Old 03-29-2017, 03:19 PM
scotch's Avatar
I am planning this. THANX
Old 05-29-2018, 05:48 AM
ZEN357's Avatar
Sounds like a valve gasket leaking. I remember having this problem on an Iron Duke motor back in the 80's from GM.
dave neo
Cuda Specific Discussion
02-06-2017 02:51 PM
H-Pattern
06-09-2010 08:09 PM
05-17-2010 08:32 PM
will d
02-13-2010 06:33 AM
dzltd02
10-28-2008 08:25 AM
Quick Reply: Oil on spark plug threads
