stalling issues
Old 01-10-2016, 02:44 PM
scotch's Avatar
stalling issues
I have a 76 Cordoba with 400. Recently after perfect starting - the car runs for about 2 minutes and then stalls abruptly. Will not restart - just cranks. After overnight - cars starts perfectly and the same - stalls and will not restart until next day. I seem to be getting plenty of fuel after the stall. I checked for resistance and continuity after cool down and - all okay. The other day, I started it and it ran perfect for all the time until I turned off. I pulled the ECU off and noticed two small areas of leaking on the back side. I am thinking some type of breakdown of a capacitor or something causing the melting and ultimate leaking. Your thoughts would be appreciated. THANX
Old 01-10-2016, 05:49 PM
Leaking not good, replace it. If it doesn't completely solve the problem look at the coil.
Old 01-12-2016, 03:34 PM
scotch's Avatar
stalling issues
Thanx so much for your reply. Any idea where to get the ECU ?
It is a 5 pin unit and all I see out there are 3 and 4 pins
Old 01-12-2016, 06:10 PM
Napa auto parts if its close....
Sirus115
01-09-2016 11:33 AM
78cordoba
04-22-2009 08:06 PM
cudaneil
03-25-2009 02:20 AM
mkendrick111
03-13-2009 10:21 AM
DartConvertible
03-17-2008 05:18 PM
Quick Reply: stalling issues
