Dodge Caliber Starting problem
on
I have a 2008 Dodge Caliber. When the car sits for 2-3 days it won' start. It acts like it is not getting any fuel. When i lift the hood and wiggle the flue line it starts. I replaced the fuel line going into the fuel rail and it didn't help. When I first purchased the car it did this and I took it to the dealer under warranty. They had it for a week and they said it did not do it for them. The problem still exists. I now took it recently to a private shop. It has been there for > 2 weeks and they said they could not duplicate this problem. Has any other Caliber folks out here had this issue? Also is their any service bulletins about this?
Also does anyone have a direct customer service email address for Chrysler I could contact. My hunch is that it may be a check-valve problem in the fuel pump but don't know.
Any help would be greatly appreciated.
I have no idea, but I would install a fuel pressure gauge taped to the windshield Drive it until it happens again. Otherwise maybe a new fuel pressure regulator. My 88 Olds has a similar problem & I have to tap the reg to get it going happened twice in 800 miles...
Run some fuel system cleaner in it !
on
The fuel pressure reads correct. What happens when it does it is I wiggle the inlet fuel line and then it starts. I replaced this line. This did not help.
No computer codes are reported.
on
No the wiggle of the flue line if what I did during my troubleshooting. Its in the shop now and they told me they checked the fuel pressure and they said it was correct.
To be clear this problem was with the car when I purchased it new. The issue is it needs to sit 2 - 3 days to do this. So for example when I take a trip and park at the airport it does not start. The issue I am sure is with fuel delivery. I can't explain moving the fuel line for it to start unless this is doing something with the check valve in the fuel pump.
Hal P. McBroom
09-30-2020 03:36 AM
Bobby-O
09-18-2014 05:46 PM
speedtriple
05-30-2008 03:45 AM
