head gasket?
Old 02-23-2017, 05:48 AM
Chryslerguy17's Avatar
head gasket?
so i got my 413 bored .030 over. im bout to order my master kit for the rebuild. what is my bore size now? a stock 413 bore gasket wont work? will a 440 head gasket work. Need help asap!!!!
Old 02-23-2017, 11:28 AM
So, what heads are you going to be using?
Old 02-23-2017, 11:33 AM
With a 413 you need to be considered with compression ratio, so what heads do you have?
Old 02-23-2017, 11:46 AM
Your not going to find the proper gasket in a master gasket set.
Old 02-23-2017, 06:20 PM
I am trying my best to find a good set of 915 heads. They are the best choice I have with th mods I'm doing to the motor.
Old 02-24-2017, 06:28 AM
If you can't find the 915s look for 2406516, 64 to 67 383 361 heads,, they're close chamber but small valve so you can put the larger valves in, ports are not as good as the 915s but close.
Cometic makes a .027 head gasket for the 413 with a 4.250 bore, yours is 4.210 perfect. You can order the .027 gasket set.
www.cometic.com
tagster
09-09-2010 01:04 PM
jascharger
07-14-2010 07:04 PM
sgp7679
01-07-2010 12:58 AM
DUST360
06-22-2009 09:32 PM
MarkyMark12345
04-16-2009 06:46 PM
Quick Reply: head gasket?
