1975 d200 issues
Old 07-18-2016, 09:13 PM
mpask's Avatar
1975 d200 issues
Okay so I have a 1975 dodge d200 camper special with a 360. I have owned it for about 2 months now and never had issues until recently. It will randomly stall and sometimes be hard to start again. I am looking for possible answers and solutions. Thanks for all replies
Old 07-19-2016, 06:33 AM
Plugged Fuel Filter or Fuel pump going bad...
Old 07-19-2016, 01:32 PM
I agree, check the fuel system over.
Old 07-19-2016, 03:18 PM
I'd be taking the fuel pump and running it in a bucket to do a timed volume test. Making sure to disable the ignition system before cranking. If it showed proper volume as per spec then the carb would be coming off for a look see and rebuild.
Now it could be something else but based on age and RV limited use sitting with an older gas tank, with your described symptoms, this is the place I would start.
Oh yes, and Welcome to the site!
Old 07-20-2016, 07:09 PM
I would look for an air leak at the fuel tank ! Replace the rubber hoses !! Next time it happens check for spark ...
Old 07-20-2016, 07:24 PM
mpask's Avatar
Update! So I replaced the fuel pump and fuel filters and it still does it. Seems to only happen when the engine gets hot. Plus it has been pretty hot where I live the past couple days so that isn't helping. Also i will add that it has a edelbrock 4 barrel carburetor and intake. Carb is a 1406 I am going to replace the rubber part of the fuel line tomorrow a wrap them in heat wrap as the lines were getting quite hot
Old 07-21-2016, 03:26 PM
mpask's Avatar
Would it be the voltage regulator causing this problem or the distributor
Old 07-21-2016, 05:21 PM
Did you confirm the fuel pump was bad before replacing? If you didn't it could still be a restricted fuel pick up in the tank. A proper and full diagnosis should be done before changing parts so you know that you have corrected the problem.
Old 07-21-2016, 05:36 PM
mpask's Avatar
No I didn't confirm that but this only happens if I drive the truck for about 20 minutes and once I let if sit a while it will be fine again for another 10-20 minutes then same thing and right before it stalls there's a big backfire. The carburetor gets hot when the motor is running could this maybe be the issue. Like you can't even touch it it's that hot
Old 07-23-2016, 04:46 PM
Douglas1300's Avatar
Vapor lock
I would look into vapor lock.
Old 08-02-2016, 04:09 PM
Carb boiling over ? Try a carb spacer/insulator!
Old 08-02-2016, 04:37 PM
mpask's Avatar
Yeah put a spacer 2" spacer in and rebuilt the carb. Still does it but not all the time. I'm going to go through all the wiring and look for a possible cause
Old 08-06-2016, 05:30 PM
mpask's Avatar
So now I have noticed a some white ish smoke coming from his back of the engine when it's been running for a while
Old 08-07-2016, 07:20 AM
That dont sound good? What is it?
Old 08-07-2016, 07:38 AM
mpask's Avatar
Not sure what it is. It's not a lot of smoke it's only noticeable when you open the hood. Don't think it's an manifold leak since I recently changed the gaskets but maybe could it possibly be the head gasket?
Old 08-07-2016, 07:42 AM
Maybe..... Or just a valve cover seeping a little and dripping on the exhaust manifold or pipe????? Check it out.... keep us posted....
Old 08-07-2016, 07:44 AM
mpask's Avatar
Would that cause my issues I've been having?
Old 08-07-2016, 09:25 AM
Head gasket would.... But not the stalling and hard start..
Old 08-07-2016, 03:35 PM
mpask's Avatar
So it did it again today after not much driving and I took a plug out and checked for spark and there was no spark. But if it sits for a bit you can drive it a little more. Like a couple blocks hen same thing. Any suggestions. Maybe the distributor rotor and cap or the ignition coil
Old 08-07-2016, 05:23 PM
sounds like it might be the ecu/module ??????
Old 08-10-2016, 05:23 PM
mpask's Avatar
Thanks everyone for the replies I have finally gotten it fixed turned out to be the ignition control module
Old 08-11-2016, 06:01 AM
Home run Bob!
Old 08-11-2016, 07:39 AM
... I need to buy a lotto ticket !!!!!!
Glad you got it fixed... Make sure the box has a good Ground to the body...
Old 08-11-2016, 07:50 AM
  #24
Are you saying luck had something to do with it, I thought you were just good.
Old 08-11-2016, 02:42 PM
  #25
Shhhhhhhhhhhhhhhh....lol
Old 09-18-2016, 12:15 PM
  #26
mpask's Avatar
what would cause this part to keep goin bad. I have to change it again as the problem is happening again
Old 09-18-2016, 12:40 PM
  #27
what are you putting in for parts, mopar, napa etc.?
Old 09-18-2016, 05:46 PM
  #28
Check or change the Dist. Pick-Up.... Also make sure you are using the write ignition coil..
Old 09-18-2016, 08:13 PM
  #29
mpask's Avatar
I'm not sure on he brand of it. would a subwoofer cause this problem
Old 09-19-2016, 06:20 PM
  #30
Not that I'm aware of...
Quick Reply: 1975 d200 issues
