79 d100 windshield wiper removal ?
Old 01-13-2016, 07:46 AM
1979-D-100custom's Avatar
Ok going to sound pretty dumb for this question but I have a 79 d100. It olny has one wiper on the truck the drivers side is gone and passenger side is there and works but the driver side don't move I can't get the passenger side off so I can try and see what's going on with it and there water that will come into cab and under dashboard any suggestions that might be able to help will be carry helpful please and thanks.
Old 01-14-2016, 08:17 AM
Does it have a post on the arm? It likely just pulls straight off, I doubt it was the hook and loop kind popular today.
Old 01-14-2016, 05:02 PM
No hook and loop that's what I thought it was the pull off kind but the darn thing won't pull off tried everything I knew to get it off it gose up a little then stops put every kind of penetrating fluid known to man but it won't budge wasn't sure if there was a special way to remove them but thank you very much for the reply
Old 01-15-2016, 08:26 AM
It is time.
Old 01-15-2016, 06:31 PM
Hay Skwerly.... Good to see you checked in.... long time no see....
79-D.... You just have to pry it off with a large blade screw driver... Mine has done the same thing.... Pry it at the cowl and the wiper arm... Sound like the bushing went bad on the arm. once you get it open you can replace the bushings and it will work just fine...
As for the water leak... That you might have to chase....
mikerp76
09-30-2011 10:04 PM
tobacjones
08-04-2011 11:50 AM
JP67
02-09-2011 06:38 PM
ronroddey
04-13-2009 02:08 AM
Piero
05-02-2008 09:26 AM
Quick Reply: 79 d100 windshield wiper removal ?
