odom. does not work
Old 11-30-2010, 01:42 PM
bltpls5's Avatar
odom. does not work
92 w150 odometor does not work speedo does. replaced the cluster still no change. help
Old 12-01-2010, 03:36 AM
That is weird. Usually the odometer works off of the speedometer. Is your speedo cable tight (the speedometer doesn't bounce around while driving)?
I'd take apart the original one and see what's up with it.
Old 12-01-2010, 03:59 AM
bltpls5's Avatar
right thats what i thought. And the back of the cluster is all electronic there is no cable.
Old 12-01-2010, 04:33 AM
I would then start to look at a wiring diagram for that circuit and go from there.
Old 05-21-2016, 05:49 AM
gwgdog66's Avatar
Sorry to chime in on an old post. I recently found this forum, and a 1990 D150 in excellent shape. Mine has the same problem. I reset the trip meter to zero after i did the first oil change and now it no longer works.
Have you found the problem to properly fix the issue?
Thanks
Old 05-22-2016, 10:14 PM
????? It is strickly a mechanical speedo, There is a small gear that connects the speedo & odo together that releases when the reset is pushed
Old 05-24-2016, 07:24 AM
gwgdog66's Avatar
Then I'm guessing that gear is stripped out. My Speedometer works just not the trip and odometer.
I guess I'll try to find a replacement unit.
Thanks again.
Old 05-24-2016, 11:06 AM
Gary... Give it a few extra snaps and see if that work.... If not check with the local speedo guy and see if he might have a gear for the unit..
Old 05-27-2016, 09:24 PM
That gear was available at one time / Not sure now !!!
Old 05-27-2016, 09:29 PM
Just for info, This is for fd http://www.ebay.com/itm/94-95-96-97-...fdeYZg&vxp=mtr
DustinHeck
11-14-2013 09:48 AM
Mopar or no Car
07-28-2013 08:53 PM
randys69charger
10-08-2012 11:24 AM
ef8340
12-17-2008 12:07 AM
Quick Reply: odom. does not work
