1964 fury engine swap info and tips wanted
I would like to replace a 318 poly with a 5.9 magnum. One thing in particular id like to know is there a bolt in radiator that plays well with an LA or Magnum motor? It looks like the lower water pump hose is on the wrong side (LA/magnum needs passenger side and poly uses driver side)
