1971 400 engine help!!!!
Old Jul 16, 2009 | 12:12 AM
sixpack71's Avatar
ihave a 71 roadrunner, it has a 71 400 block in it (casting number 9-8-71, 3614230-1) my hood reads 383, and my vin number says it came with a 383, i was wondering if they came out with 400 blocks as an option later?? any info would be appreciated!
Old Jul 16, 2009 | 06:19 AM
72RDRNR's Avatar
72 was the first year for the 400. Sounds like someone installed new engine, but the 400 is a very good motor and lots of parts available to build them - stroker kits!.
Old Jul 16, 2009 | 06:38 AM
Polaradude's Avatar
3614230 is indeed the 400. This casting # was produced in 71 & 72 and is a B block.
Old Jul 16, 2009 | 04:27 PM
the casting number means the date it was casted
if it says 71, the block was probably first used in a car in 72 or 73
Old Jul 16, 2009 | 11:33 PM
chlngr1970's Avatar
To add to the above, the 400 is in the same engine family as the 383. IIRC, it goes 350, 361, 383, 400. Then the RB engine ( Raised Block...taller deck hight ) was the 413, 426 wedge and 440. Depending on what you want out of your car, the 400 might just be perfect for you.
j
Old Jul 17, 2009 | 08:43 PM
what are your plans?
Commando
Apr 3, 2018 01:36 AM
supercharged
Jun 27, 2009 12:35 AM
Polaradude
Jan 4, 2009 11:56 AM
Commando
Jul 23, 2008 04:54 PM
djg1978
May 3, 2008 03:53 PM
