Mopar Forums (/forums/)
-   -   1971 Dodge Charger (https://moparforums.com/forums/f10/1971-dodge-charger-1475/)
Mopar71 Sep 7, 2008 11:03 PM
1971 Dodge Charger
Hi, I have a 1971 Dodge Charger 500 with a 440, some assembly required. I was wondering if anyone here knows of a good place to get interior/exterior parts for one. Thanks in advance for any help.
http://i12.photobucket.com/albums/a2...e/IMG_0801.jpg
http://i12.photobucket.com/albums/a2...e/IMG_0802.jpg
Commando Sep 8, 2008 04:03 AM
Doc, you could probably help him out with this, it looks like he is closer you.
Looks nice, what are you looking to get, front grill?
Mopar71 Sep 8, 2008 02:54 PM
The body of the car is in relatively good shape. My dad has had it in the garage for at least thirteen years now, so there isn't a lot of rust. I'm mostly looking for interior parts. The seats need to be reupholstered, the dash is cracked and most likely needs to be replaced, the ceiling is coming down and has holes in it and needs to be redone. Cheap parts for a 440 would be nice also. Piston rings, Intake Manifolds, etc. I would assume the engine parts are easier to find than the actual car parts. I just need to be pointed in the right direction :)
ef8340 Sep 8, 2008 03:56 PM
legendary interiors google that that should put you in the right dir thats where yearone gets there stuff from interior wise ,...... from what i been told but either place should have interior parts for your car
Commando Sep 8, 2008 05:29 PM
I have stock 440 engine parts if you are interested, complete intake, exhaust manifolds, water pump and cam with timing chain and lifters. Let me know if you need any of that.
pascualindio Sep 8, 2008 07:16 PM
I have a charger 1972 and I'm having the same problem
Need to know if you going original or not
I've some web addreses I can send you
Mopar71 Sep 8, 2008 11:42 PM
Thanks, for the site. Looks like they do a pretty nice job fairly cheap.
That would be great. I'll have to look over everything and get a parts listing. I'll get back to you when I do.
Send away. The only thing I've really wanted to change were the brakes. Right now it's four wheel drum brakes and I've wanted to switch it up too disk. Though I'm unsure as to how much that would cost.
I also need the roof to be redone. It's starting to wear out.
http://i12.photobucket.com/albums/a2...Dodge/vtop.jpg
lail1985 Sep 11, 2008 07:21 AM
Mopar71,
Give us a holler or check out our website, we will be happy to assist you with your interior needs. Thanks. Eric @legendary Auto Interiors
(800)363-8804
www.legendaryautointeriors.com
helomechs Sep 24, 2008 09:15 AM
ive seen lots of parts, old and new on ebay at times. i have a 72 charger. they had pretty much every panel (reman.) usually black. but i was surprised to see them on there. good $$ too...
helomechs Sep 24, 2008 09:17 AM
i put a wilwood kit on the front of mine, install is simple and it runs about 750 complete. but you have to change master cylinder, thats about 200-250 i think...
