1971 roadrunner brakes! question!?
Old Mar 13, 2008 | 03:23 PM
I'm not sure what all rear ends were supplied in 71. So far as I know, only the 8 1/4 rear, which has a 10 bolt oval shaped rear cover, uses the internal axle "c" washers. If this is the case, drain the rear, remove the rear cover, and remove the bolt holding the crosspin for the pinion gears. Now you can push each axle in to the center, remove the "C" and pull the axle out.
If you DO NOT have this type axle, just remove the 4 bolts that hold the axle retainer and brake backing plate. There should be an adjustment on one side of the car. You may need a "hammer" puller to knock the axles loose
You really need to get yourself a shop manual
Old Mar 13, 2008 | 08:25 PM
At this time, I no longer "own."
I've owned a
64 Dodge 440 (body) 426
69 RR 383 4 spd
70 RR 440 sixpack 4 spd
'62 Landcruiser 340
rixrunner
Oct 22, 2010 06:28 AM
Andre11
Sep 18, 2009 04:02 PM
sixpack71
Jul 15, 2009 10:42 PM
sixpack71
Jan 26, 2009 02:49 PM
71RR08
Sep 22, 2008 08:45 PM
