1972 b300 van advice
Hello!
I recently purchased a B300 van that was hardly used. 66000 original miles. It hasten been ran for since 1999 but it made it survived a 3 hour drive. I need to change the fuel pump and and have been advised to replace the uline barring. Is there anything else I can change/replace /upkeep to make sure the van is running in top condition? Thank you!!! My last van was a 1974 dodge tradesmen 200 with a 318 engine so I'm a little familiar. |
I have Frankenstein 74/76 with 360 and 92 trans with lockup Camper also,... just go through it fix what needs fixing, do a pre-emptive strike, But I would add a trans cooler if doing hills though.
I would replace all the rubber hoses, motor, brakes and fuel lines and belts even if they look good.
