1977 Cordoba front suspension
Old Jul 30, 2009 | 04:02 PM
have you tried adjusting the torsion bar?
Old Jul 31, 2009 | 03:48 PM
every car is rusted
as long as the parts are still solid, you can work with them
post some pics of the suspension, and we'll help you from there
Old Aug 3, 2009 | 06:56 PM
theomahamoparguy's Avatar
you can get the torsion bars pretty easy from various places.
To remove them; 1. Soak the adjusting screws with some very good penetrating oil {this is important, let soak for 24 hrsw at least}.
2. If you can ge them broke loose, unscrew the adjusting screws all
all the way
3. Remove the retaining clip in the back of the bar.[towards the
back of the car]
4. Since it seems like your bars are shot anyway, clamp something
to them [heavy vise-grips] so you have something to pound on
with a hammer and tap them out towards the rear of the car.
5. if all else fails, torch them out with oxy/acet. torch.
The Cordoba's were noted for having a very soft ride so I'm not surprised that they may have failed from sitting on them. If they dont look like they are broken, it may be possible that they copuld be adjusted up {if you are lucky}. Just turn the adjusting screws clockwise instead of counter- clockwise. To find the adjusting screws, just look at the lower controls arm, towards the center of the car, in the middle of the arm. They have a 3/4" hex on them.
Old Aug 10, 2009 | 04:51 PM
if the car has sat for years, crank the engine over my hand first before cranking it by the starter motor
Old Aug 10, 2009 | 05:30 PM
scotts74birds's Avatar
X2, plus some marvel mystery oil or similar in the cylinders for a few days first.
Old Aug 10, 2009 | 08:47 PM
if the engine turned, it isn't seized
how much resistance did you feel?
2x, tighten the starter
AlFurious
Aug 25, 2010 03:28 PM
mvanwy02
Apr 15, 2010 05:45 PM
mopar_derek
Oct 1, 2009 06:55 PM
Rosfrei
May 29, 2009 07:50 AM
Commando
Dec 24, 2008 05:42 AM
