318 to 383
318 to 383
I have a 73 road runner im swapping out the 318 to a 66 Chrysler 383 i think it came out of an imperial but im not sure.
i was wondering what im gona need to do the swap
i have a 904 torque flight but the transmission has been rebuilt with stronger parts to be able to handle the higher horse power and torque.
Your 904 wont work..cuz it has the small bell housing for the 318. You'll need to get a big block trans, just as well get you a 727. Prob need to get a stronger rear diff.. im guessing you have an 8 1/4, also consider a bigger radiator for cooling.
your going to need some motor mounts a trans adapter (big block to small block tranny) and a different tranny mount. i've never used a sb tranny behind a bb but i think they push the tranny back and i assume it will present problems with the trans mount. personally i would just use a 727 unless the 904 is what you really want for a less power robbing tranny for drag racing.
Iv'e used schumacher mounts and have been very pleased with them
A.K.A Bob Dodge
on
motor mounts, big block transmission, radiator (maybe), diff oil pan for the big block to fit k member. trans mount, some basic electrical knowledge, (extending wires)
just to name a few
just to name a few
timmie -
Yeah, pretty much - for starters. Then you have to worry about the exhaust manifolds and pipes - assuming you're going to use headers.
ive already had a raidator made for the engine
where can i find the adapter for the 904 i was hoping to use it until i find a manual tranny
if i change to a 8 3/4 do i need to change the whole rear end or just the gearing ?
A.K.A Bob Dodge
on
the rear end you wil have to cahnge the whole thing,, its not a hard job,
heavy but not hard
timmie -
What rear do you have in there now?
Also, with a new tranny/rear, you might want to plan on a new drive shaft, yolks/U-joints as well. The sizes, including length, might not match up.
I'm not sure what rear end it is
im thinking its a 8.25 because the only marking i found was T-25
i found a 8.75 third member on craigs list could i buy that and just swap out the 3rd members?
A.K.A Bob Dodge
on
no you would have to change the whole thing, also you would want to make sure it will fit you car by measuring backing plate to backing plate. (dont want a rearend sticking out 3 inches on each side,)
labradorian70
09-24-2014 09:44 AM
