440 build up.
440 build up.
Any cricism of this build would be appreciated:
440 w/ stroker crank yielding 502"
.060 over diamond forged aluminum pistons
10.5:1 compression
Edelbrock RPM Perf heads out of box (not ported)
Comp magnum steel roller rockers (rated for 350 lbs open spring pressure??)
.355 rear w/ 4 speed transmision
3500 lb. 70 Coronet R/T
6 pack carbs/edelbrock alum intake -
Not sure which cam to go with, but here is what I've narrowed it down to:
Comp Cam #s:
23-711-9 lift 541/537 Duration @ 50 230/236
23-712-9 lift 544/541 Duration @ 50 236/242
23-713-9 lift 549/544 Duration @ 50 242/248 Pro Street/ Bracket prob not for me
Any more lift than the 712 and I will need to replace the rockers which I would rather avoid unless I can really step it up a notch performance wise and still be streetable.
I'm open to other than comp cams if anyone has a suggestion. Also any info on how these cams will differ due to varied duration, lift, etc. with regards to a 500" motor would be greatly appreciated
10.5:1 compression
Comp Cam #s:
Mango
10-27-2010 06:32 PM
69coronetkyle
08-04-2009 02:22 PM
