Mopar Forums (/forums/)
-   -   440 piston to valve clearance? (https://moparforums.com/forums/f10/440-piston-valve-clearance-5583/)
bchoro Mar 9, 2010 09:34 PM
I'm in the process of rebuilding a 440. When checking for valve to piston clearance, what should it be? I've done the putty test (heads with gaskets torqued down, turned over with wrench).
What would the minium clearance be to allow for expansion?
Thanks
1966sportfury Mar 10, 2010 12:23 AM
i would contact the manufacturer of where you got your pistons. they may vary from what Chrysler used in there production engines. assuming you are using aftermarket pistions.
bchoro Mar 10, 2010 05:39 AM
I bought this engine off some hillbilly 8 years ago. This guy thought he knew how to build engines and I was young and stupid. So far I've found one push rod a different lenght (a long with that, a bent valve and cracked head) and a loose washer in the valve assembly. and i've never even had this motor in a car yet! Talk about lessons learned!
anyways, thats why I'm in the process of the re build. I seen some part # on the piston heads. I'll try googling that tonight to see what comes up.
toad490 Mar 10, 2010 11:10 AM
Most builders recommend .060, some will say as tight a .050. That's with steel rods.
bchoro Mar 10, 2010 07:29 PM
steel connecting rods?
toad490 Mar 10, 2010 10:43 PM
Yes, .010-.020 more with aluminum.
