67 Charger grille in 67 Coronet ?
1 Attachment(s)
Hey there, so I was cruising some pictures trying to decide what colour to paint my net when I came across this picture of a 67 4 door net with what appears to be the 67 charger hide away lights and grille , I wanted to make a mesh grille with the headlights behind but this looks way cooler, does anyone know anything about that grille swap or what exactly the grille in the picture is from ? thanks.
looks like someone already did the swap. Something that would be VERY expensive to do.
i bought a new 1966 dodge charger. with the hidden lights. it had two motors to flip the housing. they didnt work very good. the wiring will be a mess. if it was mine, i wouldnt put it on. new idea, if you could convert it to a manual setup that might work. just an idea.
less moving parts means less hiccups ( or problems )
I know 68 and 69 chargers had vacuum headlights, 1970 and up went to electric.. I would think 67 would have been vacuum.. I think its a cool idea, maybe convert it over to a electric set up.. I think the front fenders and bumper are the same on the 67 charger and coronet.. So if you had a donor charger front, I cant see why it would not work..
| All times are GMT -7. The time now is 05:05 AM. |
