'68 Satellite body trim
Old Oct 27, 2008 | 06:02 PM
BuckNeccid's Avatar
VERY gently lol. Actually if I remember right, it's a combination of plastic snap clips and metal bolt on clips. Look on the inside of the fenders, doors and quarters under the trim. If you see what looks like about a 3/8ths nut, that should be the metal clips. Remove them, then very easily and with a wide flat tool, like a stiff putty knife about an inch wide, slip it under the trim and easily rock it side to side to try and pop one end loose. Keep light up tension on the trim, and slide the putty knife toward the next attaching point, and repeat the process till you have it removed. You dont want to twist the trim, so be careful. Replacing it is pretty well straight forward, put it in place, slap it with the heel of your hand or tap it with a rubber hammer, then replace the nuts holding it. Hope this helps.
Jarettb
Dec 15, 2012 09:24 PM
Jarettb
Dec 12, 2012 08:43 PM
LeapYear
Jul 6, 2012 10:59 AM
P O'LARA
Feb 16, 2012 01:03 PM
Oldsmobileman
Aug 5, 2009 04:25 PM
