Mopar Forums (/forums/)
-   -   68 Satellite map light wiring and Radio (https://moparforums.com/forums/f10/68-satellite-map-light-wiring-radio-3034/)
68satellite May 13, 2009 02:05 PM
I have a 68 Satellite that did not have a map light in it. I would like to install one. I pulled off the blank plate and could not see any existing wiring to connect it to. Should it be there or do I need to run wire. Also the light in the radio is not working. Where should I start with that? Thanks Ken.
scotts74birds May 13, 2009 02:30 PM
The dome light , if equipped should be a pink wire and a yellow wire. These are on the same run as the left and right pocket panel lights and the trunk light. Might be an unused connector under the dash with these wires.http://www.mymopar.com/downloads/196...oadRunnerA.JPG I think the radio light is internal and is just a bulb.
