69 Charger brake system
I have a 69 Charger 318 A/T that is having issues with the brake booster. The car was converted to disc several years ago with parts from a 72 Plymouth B body. Trying to find a power booster/master cylinder set that will work on this car. Brake lines are on the drivers side of the master cylinder. Any suggestions on where to find a set that will work? None of the local parts stores seem to be able to help.
Maybe some photos and a casting number off the current master cylinder? and will see if we can help out.... Cheers
I bought my E body set up from Pirate Jack and it went in with no issues at all. I know its a weird name for a brake component store but a lot of the Mopar guys recommend it. They have an Ebay store under Pirate Jack Hotrod and Restoration and offer what you need. https://www.ebay.com/itm/16154492034...kAAOSwhV1ckQDL
You won't be using a stock (for drum front) unit. Look and see if there was a disk option, or the first year there was.
| All times are GMT -7. The time now is 07:05 AM. |
