73 roadrunner questions
I have 2 questions
1. Does anyone know the stock bolt pattern and the width on the stock rims? 2. Does anyone know the diameter of the stock steering wheel? I am away from my car for another 3 weeks but need to buy parts. Any help would be appreciated. |
Roadrunner Q's
Steering wheel should be 15 inch. You can put whatever on there though, as long as the hub size and splines are correct. I suggest a Tuff wheel. There are a ton of aftermarket.
You can also get originals by posting an add on for b bodys only, or watch ebay. Wheels are there all the time. #2 5 x 4 1/2 bolt pattern. Any width from 6 inches to 8 inches should be fine. I have a 73..... Troy |
Steering wheel
Check out the Grant wheels, you will need the Mopar mounting kit. They have wheels simualr to a Tuff wheel. I have a wood grain style on my car, around 15 in. dia.
