Mopar Forums (/forums/)
-   -   ^8 Road Runner Reverse Swith inop (https://moparforums.com/forums/f10/8-road-runner-reverse-swith-inop-4270/)
Airkiller Sep 20, 2009 08:42 PM
Ok here is the skinny. I have a 68 Road Runner with the reverse lights inop. I have discovered that the switch arm is missing from the top of the steering column shift rod. This arm is connected to the shift rod and moves a tab on the reverse swith to operate the lights. QUESTION: Were in the world can I find a replacement switch arm? Can anyone help me out here, PLEASE!!:eek:
theomahamoparguy Sep 21, 2009 06:08 PM
that might be tough finding that unless you raid another column from a salvage/swap meet. It may be a common part in most mopars of that year. From what I can remember, the roadrunner column was pretty standard issue. Would be nice to know what parts would interchange. I'll bet that most of the columns were the same inside.
[except for tilt units; GM based]
Crazy4Carz.Com Sep 21, 2009 07:38 PM
Save yourself the trouble. use a later model switch from a '70 up. it mounts on the trans instead of your one wire connector it will have three prongs. Neutral safety sw, and reverse lights all in one. way easier.
