Air trapped in cooling system
Old Jul 26, 2010 | 01:56 PM
68RTRick's Avatar
Junior Member
I have a 440 that I just put new Mopar Performance aluminum water pump, 180 high flow thermostat, recirc bottle and flushed the cooling system twice.
Car ran great for a couple of days it got no hotter than 205.
Let the car sit for a couple of day and drove it a medium distance and now the car is hitting 210 to 220.
Radiator is full and the fluid moves when the thermostat opens.
Saw on other forums about trapped air.
How do I get it out of my system?
Thanks.
Old Jul 27, 2010 | 04:20 PM
do you have an overflow tank?
Old Jul 27, 2010 | 06:10 PM
BIGJOHNSMOPARS's Avatar
I have had that problem. I drilled a 1/8th hole in the thermostat it lets air escape.
Old Jul 27, 2010 | 06:11 PM
pjmopar's Avatar
air
The way i do it ,but this may not be the right way ,when the motor is a little hot ,i will losen off the heater hose at the intake ,holding the hose firmly ,until the air comes out and you see coolant.,then tighten the clamp back up.Be very careful.Like i said it may not be a good way,but its the way i do it
Old Jul 28, 2010 | 06:10 AM
1966sportfury's Avatar
A.K.A Bob Dodge
agree
Old Jul 30, 2010 | 11:25 AM
64fury's Avatar
Pressure relief rad cap, the ones with either a button or lever, you lift/push before taking the cap off to prevent hot coolant from overflowing.
Get one of those and when the engine is hot, release the pressure/air my lifting the lver, do not hake the cap off, just release the pressure.
You also may have a leak allowing air to get into the cooling system, may need to track that down to, a pin ***** hole in a hose can allow air in but small enough not to aloows coolant out!
Old Aug 10, 2010 | 08:50 PM
Live Wire's Avatar
Try a Mr Gasket high flow thermostat, it comes with a small hole already drilled in it. You may also want to consider raising the front of your car, removing the rad cap and then running the engine up to temperature. The thermostate will open (180F) and you'll note the coolant will start to circulate; visable as a swirlling motion. If air was trapped you'll also note sporatic bubbling or burping. Carefully replace the rad cap before shutting the engine down.
keylargo
Jan 10, 2014 05:12 PM
jkotis
Sep 20, 2013 03:28 PM
901-Memphis
Sep 20, 2012 09:54 PM
69POLARA383
Jun 22, 2012 02:46 PM
JETBLU
Apr 25, 2012 04:37 AM
