Battery cable
On my 67 coronet R/T with a 440 Is there an easy way to remove the battery cable from the starter without dropping the starter. You can just see the terminal from above.
Good to see you pop in here Chuck.... Did you get it handled ????
I used to be able to do this easy on my 69 and 70 RR I don't recall any particular grief, although I was in my 20's back then
Had to drop the starter. No way I could get to it from the top. I'm 80 it"s
getting tough to do these things. |
I hope I'm still in that good of shape when I'm 80
| All times are GMT -7. The time now is 05:08 AM. |
