Mopar Forums (/forums/)
-   -   Brake light question (https://moparforums.com/forums/f10/brake-light-question-1631/)
roadrunnerrelic Oct 12, 2008 05:37 PM
Hello, I have a 70 roadrunner that I bought in pieces years ago. I am now putting hte car together and the brake lights will not work. The flashers work, the driving lights work, but no brake lights. The front bumper is not on, so the front turn signals are not connected. Would this have anything to do with it? I tested the white lead to the brake light switch, which is hot and the pink wires are hot when the pedal is depressed. Any help would be greatly appreciated!
BuckNeccid Oct 13, 2008 02:52 AM
Sounds like a bad turn signal switch. The brake lights go thru the switch and are passed back and forth when you turn your turn signals on. When they are not on, there is a connection that only turns on the brake lights. Just plug in your front turn signals, and see if they work too. If they do, it could STILL be the switch because of how the wiring is set, but if they don't, then you pretty well know you have a problem in that area, and wires to chase to be sure it's the switch and not the wiring to the switch or after.
roadrunnerrelic Oct 13, 2008 04:21 PM
**update** I reconnected the front turn signals and they did not work. The flasher was bad and when I replaced it, the signals work fine. Still no brake lights though. Does this isolate the problem to the switch? Thanks in advance!
BuckNeccid Oct 14, 2008 02:47 AM
Most likely... From here, what I'd do is put something between the brake light switch and the activator so they would stay on, and then use a test light. Probe to the leads into the turn signal switch to make sure the power goes into your steering column. If it does, then probe the leads coming out of the column and going to the rear. If they have power, then it's somewhere between there and the back. If they dont have power, it's the switch. What I should have said to begin with is you're most likely right, that pretty well limits it to the turn signal switch.
roadrunnerrelic Oct 16, 2008 05:08 PM
Thank you for your help! I got the switch today, installed it and now the brake lights work like a charm. I truly appreciate the help!
BuckNeccid Oct 17, 2008 12:51 AM
Glad to hear that Roadrunner. Now people will know when you're gonna stop. They already know it's designed to MOVE :)
challenger Oct 17, 2008 12:23 PM
At least now the chebys and ferds will no when you are stoping for them to catch up http://www.moparnuts.com/forums/imag...es/2thumbs.gif
