drive line length
Putting an 8.75 under my 70' Charger to replace the 8.25. Specs show the 8.75 is .66 inch longer from axle center line to U-joint center line. Is that enough to require a shorter driveline or, is there .66 inch of forgiveness in the set up.
Shove it all the way in the trans.... then if it has about 3/4" and you can still put it in the pinion sattle… your good to go... just my 2 cents
Make it 4 cents, agree.
If it fits and works I would go with it. Agree!!
