Mopar Forums (/forums/)
-   -   engine rebuilders in So. Cal. (https://moparforums.com/forums/f10/engine-rebuilders-so-cal-22979/)
Jim Shafer Feb 5, 2020 07:53 PM
I have an original owner 69 Charger R/T and am looking for any recommendations of reputable engine rebuilders in So.Cal. ideally with good familiarity of Mopar engines. Any advise is greatly appreciated.
Skwerly Feb 6, 2020 08:09 AM
As far as I know (and I've admittedly been out of the loop for a little while), Wayne's in Riverside has the best local rep hands down. He's been around a loooooooong time.
http://www.waynesengines.com/
Jim Shafer Feb 6, 2020 01:13 PM
Thank you. I'll check it out.
RacerHog Feb 7, 2020 07:43 AM
I would also put JMS (Johnson Machine Service) in El Monte CAL.... Just an FYI, They do stock stuff also.
https://jmsracingengines.com/
Also
Check with Bob Mosher and the boys and see if Dale Reed is up to doing one for you. He is in Baldwin Park CA
http://www.moparsbymosher.com/friends/dale_reed.htm
Also been around a while a little more cheeper, has done work for some of my customers is
J & A Engine Rebuilding in Azusa
https://www.bing.com/maps?osid=6e207...=2&form=S00027
