Fiberglass repair on '74 Charger grille
The grille on my Charger broke and was missing a chunk for the longest time. I decided to actually be proactive today and get after it. Firgured I'd share my experience.
This is not my first time working with fiberglass. I also fiberglassed over my 1995 Ram dash in order to fit a double-din radio correctly. I started with a piece of tin siding I had laying around and cut it to fit the hole. This for for support of the fiberglass and to help keep it straight. I used two small strips of blue tape to hold it into place while I laid the glass. This was actually a pretty straight forward repair. It will require some sanding and shaping, but it should turn out!
The Subject:![Name: IMG_4556_zpsxtbi93zb.jpg
Size: 256.9 KB](/forums/attachments/f10/11632d1501526193-fiberglass-repair-74-charger-grille-img_4556_zpsxtbi93zb.jpg)
The Grand Canyon gap in the Grille:![Name: IMG_4558_zpsavc9jxmq.jpg
Size: 211.7 KB](/forums/attachments/f10/11633d1501526193-fiberglass-repair-74-charger-grille-img_4558_zpsavc9jxmq.jpg)
First couple layers of glass:
Will update as time moves on.
The Subject:
![Name: IMG_4559_zpsi4nz3th5.jpg
Size: 240.2 KB](/forums/attachments/f10/11634d1501526193-fiberglass-repair-74-charger-grille-img_4559_zpsi4nz3th5.jpg)
dnlwstwd
10-12-2011 08:08 AM
72Scampman
01-30-2010 09:49 PM
