Finally Got a 4bbl Intake!
Old May 18, 2012 | 05:24 PM
66coronet440's Avatar
Post Finally Got a 4bbl Intake!
Hi, guys its been a while. I finally managed to get a single 4 barrel intake (casting number 2206384 and afb carb for my 318 poly, clutch-type suregrip, 3.23 gears. Just wondering what needs to be done to put this intake and carb on. Also the id tag was missing and wanted to know how i can figure out the cfm rating. (the top air-horn says "6-1571", and the middle says "0-1360") Thanks
_______________________
1966 Coronet 440 318 poly
Old May 18, 2012 | 05:59 PM
This should help: http://board.moparts.org/ubbthreads/...BTuningSml.pdf
Print this one off for sure.
Old May 19, 2012 | 12:30 PM
Thanks, but it still doesnt tell me the cfm rating, how can i find that out? This intake is off a 60's 318 poly marine engine.
Old May 20, 2012 | 10:45 AM
Silverick's Avatar
I didn't look myself but, this link may help you....
http://www.carbkitsource.com/carbs/t...AVS-index.html
Old May 21, 2012 | 07:45 AM
I checked that site and for some reason it doesnt have my carb on there... weird. Would it make a difference that its off a marine engine? on the bottom casting on the carb reads "3213s". Also im wondering how to to get the carb studs out, are they threaded? thanks
Old May 21, 2012 | 08:33 AM
MrOldart2U's Avatar
Yes some times marine equip is in theyre own little niche. And the studs SHOULD be threaded, BUT it being a marine item, not 100% sure... Might search for some boat forums for your answers....
rcknrolfender79
Mar 18, 2010 11:02 AM
rcknrolfender79
Feb 1, 2010 04:42 PM
xynicgreven
Jan 25, 2010 09:02 PM
Crazy4Carz.Com
Sep 28, 2009 11:57 AM
rogers66
May 7, 2009 06:01 PM
