Firing Order
I understand the firing order. And I know it's counter clockwise on a 383. But can someone tell me how to identify which cylinder is #1 on the dist cap? Where to get started?
Joe |
I will put a picture up after work Monday. If you dont want to wait you can set the eng. at TDC number 1 cyl. on the compresion stroke. Pull the cap and see which terminal the rotor is pointing at. Thats number 1.
Just a red "X" Apollo. |
Thanks, as it turned out it was the #7 plug wire not on properly. Big differance....
Joe |
I'd sure like to see the picture as I have the same problem
I just got a 64 300 convertable with a 383 and would like some help
thanks, stu powell
Originally Posted by OutlawCuda
(Post 29719)
