Mopar Forums (/forums/)
-   -   heater fan not working (https://moparforums.com/forums/f10/heater-fan-not-working-1247/)
gilesie Jul 13, 2008 01:26 AM
I have a 63 Australian Dodge Phoenix (based on the 440)
the heater fan does not work
I believe it may have something to do with the vacuum switch but am unsure. I followed the wire from the fuse box ( the second black wire)
and it went to an electronic style box.
the interesting thing is that acording to the workshop manual is that the wire I was chaseing is the correct wire (black in color) goes to a vacuum switch, from the vacuum switch it leaves via a violet wire ( this box had a figure 8 cable leaving it(which has power)). I has been cut off and left under the dash.
Also the manual I have is for the 64 model and is a US book
To the best of my knowledge no Australian car was fitted with air conditioning (having said that my car does have an A/C bracket fitted to the motor):confused:.
64fury Jul 13, 2008 07:40 AM
On my 64' the motor had two wires one was a ground and was grounded to the heater box, the second went from the fan motor to a 3 pin connector on the other side of the heater box above the heater valve, of the 3 pins, one was the wire going to the heater motor, the other two went to the dash mounted heater control switch, power came to the switch from the fuse box from a fourth wire!
gilesie Jul 14, 2008 02:29 AM
thanks.
If I get home early enough one night I will pop my head back under the dash.
