Need som help with fender/vin tag decoding, roadrunner ´68
2 Attachment(s)
Hi!
I have some questions regarding a fender tag on a roadrunner im thinking of buying... The problem is on the second line there is a big Z, and that make me really confused. What does that mean? Would be really thankfull if someone here could help me and decode this! /Daniel |
Isn´t there anyone who can help me ?
There is plenty of knowledge here, be patient and someone will surely have the answer to your question.
Originally Posted by mr340
(Post 90247)
Hmmm, looking at the two different tags there? Are they off the same car, cause they don't look like they match. Am I wrong? I've had a couple of beers.
Marty |
Also, the only reference to a Z seems to refer to a special order V8 on 70 to 74 models, which might apply to the left hand tag in the pics. Somebody correct me if I am wrong, but I am interpreting the left hand pic as a VIN from a 72.
Marty |
The left pic (the fender tag) is absolutely not from a '70 or newer car. The body designation is the same on both the FT and the VIN RM21.
Here is what I was able to gather... The character under the "B" doesn't come up anywhere. RM21 CAR: Plymouth RoadRunner 2 Door Pillar Coupe 62 ENGINE: 383cid 4-bbl HP V8 5 TRANSMISSION: 3-Speed Automatic 44 TIRES: F70x14 Red Side Wall, Steel Belted 709 BUILD DATE: July 09. 48 AXLE: 3.23 Rear Axle Ratio, Sure Grip H4B INTERIOR: High Trim Grade, Vinyl Split Bench Seats. Light Blue Interior. QQ1 PAINT: Monotone Bright Blue Metallic Paint. U OTHER: Light Blue Metallic Upper Door Frame Color. MOLDINGS: 25: Drip Rail Mouldings 47: 'B' Pillar Mouldings (for coupe) ABC OPTIONS: F0: Decor Package R1: AM Radio Z8: Performance Hood Treatment (Roadrunner/GTX) abc OPTIONS: NONE |
OK, I can see now that the figure I had interpreted as a G is really a 6. But, now my question is...the two tags don't match...or am I missing something?
Marty (3 more beers) |
