Mopar Forums (/forums/)
-   -   Help, Leak I cannot spot down (https://moparforums.com/forums/f10/help-leak-i-cannot-spot-down-567/)
wheelman487 Jan 1, 2008 09:04 PM
I had just filled my coolent level and drove the car after I noticed I had a puddle of Coolent on top of my water pump, I cleaned it up drove the car again and there was another puddle. I have no idea where its comming from Its not the hose but there is nothing elese up there. if someone knows what this can be please help
Commando Jan 2, 2008 03:34 PM
I assume you are referring to the hose going into the thermostat, there are two hoses on top of mine, a thermo sensor and a vacuum. If its not the hoses I would check the sensor, is it a drip from higher up, or running down the hose, also do you have a clamp on the hose?
ucfierocharger Jan 3, 2008 08:54 PM
I had that problem with my 318 charger, I cant remeber where it was leaking though, If I remember right it was leaking out the water pump gasket and just bubbling up and into
