Horsepower estimates
Anyone out htere want to critique a couple of 440's? I'm curious of what horsepower these motors are probably worth given obvious variables.
1- 78 block w/trw .150 in the hole, 516 heads ,1 7/8 headers, 3" exh, 6bbl, stamped steel rockers. compression ~8.75 to 1?
comp hyd flat cam:
rpm 2300-6500
valve timing .006 cntr angl 110 intake ctr line 106
duration 284/296 @.50" 240/246
valve lift .507/.510 lobe lift 338/340
timing @ .015 lift intake-36 btdc 68 abdc exh 82 bbdc 34 atdc
2- 69 block w/ J&E pistons, edelbrock rpm perf heads, 1 7/8 headers, 3" exh, 6bbl, comp steel roller rockers. comp 10.25 to 1
comp solid flat cam:
rpm 3200-7000
valve timing .015 lobe ctr angle 110 intake cntr line 106
duration 290/298 @ .50" 252/260
valve lift .540/.558 lobe lift 361/373
timing @ .015 lift intake-39 btdc 71 abdc exh 83 bbdc 35 atdc
If anyone out there would like to take an educated guess of how different these 2 motors will perform, I'd love to here it.
comp hyd flat cam:
rpm 2300-6500
rpm 3200-7000
COMPCAM has a free program you can download. It will figure out the HP when you fill in the variables. Try it. ..http://compcams.com/camquest/default.asp
