How to lower my....
There is a torsion bar adjustment bolt in the center on each of the lower control arms. Turn them clockwise and count the turns so, you get both sides even. This will bring the front end down but, will create negative camber (the bottom of the wheels will stick out further than the top).
Take it to the alignment shop and have them make the adjustments and an alignment.
One thing though: If you go too low, you will be bouncing on the stops. Not good!
