Mopar Forums (/forums/)
-   -   Just picked up a 65 Belvedere II that needs lots of work.. need some help! (https://moparforums.com/forums/f10/just-picked-up-65-belvedere-ii-needs-lots-work-need-some-help-7503/)
Theo VR4 Sep 18, 2010 11:54 PM
Hey guys,
Im pretty new to the mopar scene here. I just picked up a 1965 Plymouth Belvedere II as a fun project car. It has the 225 slant 6 with the 3 speed automatic. I bought it from the original owner, with 95,000 miles. It is a four door car, and it is in VERY rough shape.
It runs and drives perfect (re built engine, new brakes, and tons of other new parts) but looks like complete crap. Tons of rust, interior sucks, etc..
I just need some help with a few things that arent working on here:
1. Only the passenger side rear window rolls down. The driver front window goes down an inch, the passenger side front goes down about the same, and the driver rear wont budge at all. Is there any way to free these windows up?
2. Only the passenger side front door works. The driver front door did work, but now when I press the button to open it it feels like its not catching or something? The rear doors seem to be almost seized shut. Is there any way to get the doors open with out prying them?
3. And finally the headlights dont work.. All of the other lights do (blinkers, reverse, tail lights etc..) but the headlights do not. Before I go out and buy new lights I want to make sure its the lights themselves, and not the wiring. Is there any way to test these?
Basically what I plan on doing with this car is just to make it a fun cruiser/rat rod. Eventually once I find all of the panels I plan on doing a resto.
Thanks in advance.. Heres a few pics by the way.. it looks a little cleaner since I took these lol
http://img.photobucket.com/albums/v2...Belvedere8.jpg
http://img.photobucket.com/albums/v2...Belvedere3.jpg
http://img.photobucket.com/albums/v2...Belvedere9.jpg
http://img.photobucket.com/albums/v2...Belvedere2.jpg
http://img.photobucket.com/albums/v2...lvedere1-1.jpg
http://img.photobucket.com/albums/v2...Belvedere5.jpg
http://img.photobucket.com/albums/v2...5Belvedere.jpg
1966sportfury Sep 19, 2010 02:07 AM
as far as the doors and windows you should be able to pop the door panels off with the door closed, may have to remove the rear seat, from there you can see if there is any problem with the window track or arms. latch theirs a rod that mite of came off you should be able to pull on that to open the door. headlights just pull the plug off the back of the lights and hook them up to a 12volt power source, they are lights and dont have to worry about hooking them up backward,s they will work anyway you wire them, if the work then its either fuse, relay, switch or harness
mr340 Sep 19, 2010 04:52 AM
Welcome to the forum (from the west side of Warren county), I saw that car on labor day weekend, I was gonna stop , but my wife would kill me if I bring home another project.
You can test the wiring by pulling the plug from the lamp and checking for 12 vdc at the plug with the switch in the on position. Try turning on the high beams,there is a foot switch on the left side next to the brake pedal.
Silverick Sep 19, 2010 08:20 AM
welcome!
Theo VR4 Sep 19, 2010 09:37 AM
Thanks for the warm welcomes everyone!
I will try taking off the door panels some time this week and see if I notice anything.
And thank you for telling me about the foot switch for the hi beams, probably never would have found that lol.
Ill update this thread as I fix the car up. I should have it on the lift sometime this week to replace a few things. Then I guess I will really get to see how badly rusted this car is lol.
Thanks again everyone!
Theo VR4 Sep 19, 2010 09:53 AM
I also found a ton of parts in this car, new fuel pump, new fuel sending unit, new wheel brake cylinder, new shoes, new ignition coil and a bunch of other parts as well. Ive basically been able to identify everything, except these 2 things here.
Here are some pictures. Just curious as to what vehicle these wheel covers belong to, and I am trying to figure out what this mirror thing that has service information on it is..
http://i205.photobucket.com/albums/b...E/IMG_2479.jpg
http://i205.photobucket.com/albums/b...E/IMG_2483.jpg
http://i205.photobucket.com/albums/b...E/IMG_2484.jpg
http://i205.photobucket.com/albums/b...E/IMG_2485.jpg
http://i205.photobucket.com/albums/b...E/IMG_2486.jpg
http://i205.photobucket.com/albums/b...E/IMG_2487.jpg
samuelcosmo76 Sep 19, 2010 10:12 AM
welcome!
those hub caps are like the ones on my dart.
mr340 Sep 19, 2010 10:27 AM
Those caps look like 73 and up Dart
Theo VR4 Sep 19, 2010 11:12 AM
Yup just checked and you guys are correct. Dont know why they were in the trunk of my car, maybe he had them as an extra set.
Theo VR4 Sep 19, 2010 05:24 PM
Ok I managed to get the headlights working tonight... turns out both lights were bad. Replaced them and just like that, they worked perfect.
Now I have discovered that my fuel guage works some what intermitently. Do you guys think it could be a bad float or sending unit?
MoparOnly Sep 19, 2010 06:17 PM
If it's intermittently it might just be a bad ground. I'm not exactly sure on the 65's but later years had a ground strap that snapped one end on the fuel sender pipe and the other end to the fuel line. This completed the ground by bypassing the rubber hose. Pull it loose and clean up the ends and the pipes with some sandpaper and snap it back on.
Theo VR4 Sep 19, 2010 07:04 PM
Cool, ill check into that. I should have it on the lift some time this week to mess around with it. Thanks again
Theo VR4 Sep 20, 2010 07:49 PM
Can you guys point me in the direction as to where the fuse box is on this car? I cant seem to find it.. i know its sad lol
thanks!
